Old Aug 17, 2015, 12:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Adding a 90mm throttle body
Old Mar 18, 2011 | 07:42 PM
bohrman44's Avatar
bohrman44
Default Adding a 90mm throttle body
I have been kicking around the idea of doing this......has anyone done this....is it simply a bolt-on application? I have done some research and havent really found a lot......any help or ideas would be most appreciated!
I have the Mopar CAI installed and a superchips tuner on my 09 5.7 hemi...
Old Mar 18, 2011 | 08:21 PM
jayman84's Avatar
jayman84
I have a ported 85mm one on my truck simply because the research i found showed that a 90mm one would be overkill and require a tune and I didnt have a programer at that time. I noticed a bit of a difference when I changed it but nothing serious but hey every little mod adds up. It was super easy to swap them out and took me all of about 20 minutes.
Old Mar 18, 2011 | 10:09 PM
roberttheall's Avatar
roberttheall
BBK makes both an 85 and 90 mm they say no new tuning is required, complete bolt on plug and play, alreay has electrionics in it. bot they are both well over 400.00 bucks. for an added 12-15 HP.
Old Mar 18, 2011 | 11:58 PM
eclipsems's Avatar
eclipsems
Purchased this ported stock throttle body from FastMan.
http://www.thefastman.com/ThrottlebodiesHemi.asp
Quick bolt-on, and truck does seem to idle smoother.
Old Mar 19, 2011 | 07:00 AM
TDTIPMO's Avatar
TDTIPMO
From what I understand, the 90mm is for serious modded engines. If all you have is a CAI and a tuner, I would stick with the 85mm. $400 seems a little high to me. I've seen them for around $200-$250. It's completly plug and play. Just remove the old one and install the new one. That easy.
Old Mar 19, 2011 | 10:27 PM
roberttheall
From the searching I've done the ones for around 200 are for older 2nd and 3rd gen Hemi, not 4th generation. If you can find one for 200 I'd like to know where. 450.00 may not be bad considering shophemi.com has a complete plug and play 90 mm throttle body that is over $1000.
I'm toying with the idea of getting one myself. I'll probly go with an 85mm.
Old Mar 20, 2011 | 12:39 AM
sking's Avatar
sking
People pay that for a new air intake and get maybe 5hp.
Old Mar 20, 2011 | 06:53 AM
TDTIPMO's Avatar
TDTIPMO
http://moesperformance.com/index.php...ducts_id=12224
85mm for $255
Old Mar 20, 2011 | 12:28 PM
RTCarlin's Avatar
RTCarlin
There's about 100 things I would do first before going this route. Based on performance 101, the gains you would see with this mod on an otherwise stock motor would be negligible or non-existent. Unless you plan on upgrading everything else in the airflow department (heads, headers, exhaust, etc) the extra air is gonna be bottle-necked somewhere along the line.
Quote from Moe's Performance regarding the 85mm ported part, "We have proven track results! *********.com member Sawcut64 has improved 1/8th mile times of "Half of a tenth" gain." $400 to go from a 10.5 to a 10.45 doesn't do much to motivate me...
FWIW, I have a mid-10 sec Buick GN that still has the stock TB, doghouse, and intake manifold... The gains from upgrading these parts were not worth the hassle, IMO...
---Ron
Old Mar 20, 2011 | 04:39 PM
bohrman44's Avatar
bohrman44
---Ron
thanks......i just wonderd if anyone has done this swap and if so were the results noticable? maybe i'll just save lots ad lots of pennies and dollars and get a SC.....
